ND5 XS and Spotify / iRadio
Just got my hands on a lovely ND5 XS of which it sounds great via Tidal, however I’m unable to get it working with Spotify Connect or any internet radio.
Looking at other threads on these topics, it says that it needs to be running firmware version 4.9 (which it is, 4.9.40) and the latest Naim / Focal app (which I am) so any ideas how to get both Spotify and iRadio working please?
Thanks in advance.
I’ve been reviewing other similar topics on the forum and trying the various things suggested on those but still to no avail so was wondering if anybody had a similar experience or offer any other advice?
I’ve tried to reinstall the 4.9 firmware update however it always get stuck on the final part where it restarts and says ‘Updating Streamer Code’ - I then get the message that the product can’t be detected on the network (even tough it did before when it was updating ARM code etc.) and even when adding in the IP address manually as it asks, it won’t go any further.
The machine itself says it’s running 4.9.40 so not sure if it is or isn’t and if that’s the reason why I can’t get Spotify or iRadio at all?
I’ve done the various checks that other topics have suggested (most up to date app, that my machine has the 24/192 boards which it does, it’s a 2017 model), so I’m now really at a loss as to what to do next?
Should I take it back to 4.8 firmware and see if that works and try again to update to 4.9 from there? Really new to the world of Naim streamers so and comments, advice would be appreciated.
Here’s the message I get from my Mac when trying to do the firmware update and the screen of my ND5 XS showing the IP address:
If you’re already on 4.9 it shouldn’t be necessary to run the update again, although trying it may help if the update didn’t run properly last time. Did you factory reset the streamer after the successful update: this is advised by Naim and sometimes resolves problems.
When attempting the update again, are you sure the computer is set up properly? It requires both a connection to your home network (preferably wired for reliability) and a direct USB connection to the streamer with the right driver running.
If all that is in place, trying the previous 4.8 update will do no harm.
You are entering the IP address incorrectly. It should not have the 1 between the 192 and the 168.
Ah - good spot, maybe I should use my glasses next time!!
I’ll try again later when I’m home with correct IP address and see if that will help
So, some better news to report this evening.
I tried the update to 4.9 again this evening and it managed to get all the way through without stalling or indeed asking for the IP address of the unit.
I performed a factory reset and a power on / off as per the guidance and sat eagerly awaiting the unit to turn back on and lo and behold, I can now stream internet radio…
However, I still can’t stream Spotify - get same message as I did before saying Spotify Connect no longer works with Naim ND5 XS (as per below).
Anyone get any ideas / tips on how to get it to work with Spotify Connect please?
Have you tried playing a lossy track from Spotify? Lossless is not supported by Naim’s 1st gen. streamers.
Thanks - yes, I’d thought of that but it’s the same with ‘Normal’ resolution files from Spotify (as below image)
Strange, as far as I’m aware Spotify still works with all Naim streamers. I would give Naim support a call and see if they can investigate.
Have you enabled Spotify in the App? It’s under Streaming Services, rather than inputs. It’s like that on my Atom, from memory I think it’s the same on the ND5XS. It may be that the update has turned it off.
Is the Spotify input enabled? I suggested this on another thread about the same problem but didn’t get a reply. Always worth checking whether things have been switched off after running an update.
Thanks for the suggestions but all appears to be enabled in apps and on the unit itself - I’ve even tried setting to the lowest available bit rate but still no joy
This is certainly a weird one. My ND5XS is running Spotify fine but it’s on firmware 4.8. I wonder if 4.9 is the culprit? I think 4.9 was mainly for Tidal login changes so I wonder if Spotify users ever bothered with it?
Thanks but I read that you need to be on 4.9 to Stream Spotify in 1st place?
Unit was on 4.8 when I got it and it wouldn’t work with Spotify or iRadio which is why I performed the update in the first place. Good news is I now get radio but still no Spotify
You certainly don’t need 4.9 for Spotify. What has Naim support said about it?
Mystery solved. Mine would probably seem to be living on borrowed time if this is the case.
Spotify Connect is no longer supported on your device
If your device shows the message “No longer works with Spotify,” its built-in Spotify Connect connection is no longer supported. You may still be able to listen on it using Bluetooth, AirPlay, or an audio cable.
Why support is ending
Some older devices use outdated technology to connect and stream from Spotify that no longer meets our security standards. We’re ending support for these connections to reduce security risks and help protect Spotify and the content available on our service.
Note: This doesn’t affect your Spotify account or any other devices you use with Spotify.
One for @Stevesky , I think.
I doubt anything can be done as the Spotify libraries aren’t available any more for the old platform. Looks like I need another PRIMARE NP5 :zany_face:.
Given that there are a fair few 1st gen streamers still in use it’s a bit odd that so few users have so far reported this problem. Perhaps most are using Tidal instead. Also odd that there has been no announcement of this if it’s a planned move by Spotify, albeit they may, as a large global corporation, see the likes of Naim as being insignificant.
Still, there is always a workaround. Not Airplay, but some 1st gen streamers support Bluetooth and virtually all support iOS devices via USB.
The problem isn’t affecting me right now. I suppose it’s possibly a glitch somewhere affecting only certain accounts. That Spotify article isn’t dated so it’s not possible to determine whether this is something new. It’s only to be expected though that old connection methods should be dropped as technology moves on.
