I have enjoyed my original ND5 XS for many years but I’m finding the functionality a little tiresome.
I have the latest firmware and my App is up to date.
I have low resolution album art via my Synology NAS, iRadio does not work for me, Tidal is very hit and miss often requiring a system reset following a hung App, my screen failed (I replaced it myself and now working) and I can no longer adjust the volume via the App.
I would like modern functionality, I would like to plug in a large capacity flash drive to relieve my aging Synology of media duties. A colour display would be nice and of course good sound quality is paramount.
My current system consists of ND5 XS, Nait XS, Focal Aria 926 with Tellurium Q Blue cable, Clear Audio Concept TT with Nagaoka MP-200 and Cambridge Audio Alva Duo phono stage.
Options I’m considering:
Buy a WiiM Ultra
Buy a WiiM Ultra and use as a digital transport to the ND5 XS DAC
Buy a WiiM Ultra and use as a digital transport to a dedicated DAC
I’m open to any other suggestions and wouldn’t be offended if the Forum thought this was folly.
I would go for option 2, as I think it will give you better SQ than option 1. It would be cheaper than option 3, which would require you to buy a dedicated DAC.
With options 2 and 3 you could use the cheaper WiiM pro unless you need the touch screen. I’d be inclined to start with option 2 which might be all you need.
Hi @Alex I have just added a Wiim Ultra to my NDX2.
Reasons: a) occasionally during peak listening hours, I get Tidal cut outs. It seems to be better with the Wiim than the Naim, no idea why; b) experiment with the equalizer; c) get room correction; and d) get a cheap (GBP250) multiroom option for circumstances when the highest quality possible is not necessary/desired.
The Wiim app is very good. Quicker and smoother than the Naim app and more user friendly. I’ve used the Wiim equaliser most for low level listening and to smooth out the sound on some indie rock rough recordings. Using the NDX2 on its own, i.e. without equaliser and room correction, is a better overall result and if you want the full Naim sound it is great.
So now I have options and at a pretty good price. If I were you, I’d try option 2. If you could find a used NDAC, consider replacing the ND5XS.
I see nothing untoward in buying WiiM, BlueSound, or any other streaming machine. What you are describing is a bridge where a machine with the latest software is attached to an older machine to access its better quality DAC and power outlet .
If it wasn’t for Naim’s trade in offer I may well have done that myself ( using a UnitiQute 2)
Not my experience. Locally stored files are presented by WiiM’s control app as a list rather than a grid which can make searching through a couple of hundred albums a pain. Naim’s radio offering is by far the best I’ve come across and far better than WiiM for listening to BBC stations in their highest available quality. And WiiM doesn’t support Presto integration in spite of promising to do so ages ago. We’re still waiting for that on 2nd generation Musos but it is up and running and works nicely on my Atom.
I’ve used a Mogami 75 ohm digital coaxial. You could also use the optical cable that comes with the Wiim. I would also add that to get the best out of the Wiim, I’ve found that the volume should be 50-70, the equaliser used to your taste and if you can avoid it, not flat, plus room correction used.
