I’ve searched, but not turned up any answers to this very obvious question. Looking at the rear panels of both devices, do you connect an ND5 XS to an nDAC using a BNC-to-BNC patch cable? The nDAC that I’ve bought only comes with a mains lead.
RCA connectors are very common on coax cables and sockets, so it’s just a convenience for easy connection. Not sure why Naim chose to provide it.
Naim have always preferred coax to optical SPDIF, I guess they have optimised their gear around it.
2 BNC (electrical)
2 RCA (electrical)
4 optical “paired” with the 4 electrical inputs…
Edit: on rereading the manual, each electrical/optical pair is somewhat sophisticated. You can connect to the electrical and the optical inputs of a pair and the DAC decides which input has valid data on it and switches accordingly. Clever!
The Linn Numerik, has something akin to this, where the DAC defaults to Input 2 unless there is a data stream present on Input 1. So my “always on” streamer is connected to the default input and the Karik CDP is connected to the “override” input.
This SPDIF via RCA socket as you say is appropriate with Naim dacs?
Is it optimal if I use the Grimm into Nds ?
Is it the same as Naim digital out on Nds?
The Grimm digital output is AES3 so you’d need a converter (basically a small transformer - Neutrik do them) to convert the balanced AES3 to single ended coaxial, suitable for the NDS digital input.
