ND555 Automation port
Apologies, if this is a silly question but It’s not easy to check behind my Fraim as to which port I need to connect a 3mm cable to set up system automation.
I just had a look at the online manual but it wasn’t clear to me.
Also I presume the Rc5 port on the 552 is RCA? So I would need 3.5mm to RCA Mono cable
Yep. A 3.5mm mono jack to RCA cable is what you need. Connect it to the IR Out socket on the ND555
Thanks James, couldn’t see it but that makes sense. I’ll get a touch!
