ND555 clock is off
As above, my ND555 is showing two hours early when set to the correct time zone. Anyone else had this problem? Fix?
well not with a 555 but today exact same issues on a windows PC! wonder therefore if some weird things going on with the time servers today ! Had to reboot toggle auto DST a couple of times , enter time manually, then toggle back to auto time and auto DST and finally got the two hours back! Gaz
I don’t have a ND555 but something I’m seeing on my ND5xs2 which is a little odd. My Timezone setting says America/Los_Angeles, but I can only “Choose your country” I don’t know where to change timezones is located on the latest version of the firmware.
Apologies for the thread drift.
(Disregard, I figured out the timezone issue. If I switch to another Country then back to the USA then I see the timezones)
When it was first produced, it was considered to be ahead of its time. :blush:
I bought a second hand IPad Pro 2 years ago. I have done a factory reset and I choosed my country. But it’s still registered to UK , don’t know why. Hopefully the hour is right.
Without sounding patronising, have you tried a factory reset? I find this often solves most problems with electronic devices.
I have.
Try resetting it to a different time zone and then reset to your time zone I had to do this with my ND555 sometime ago.
I’ve tried that a few times, no luck. Odd behavior.
