Note the lack of logo light (nor button lights, though I usually dim those). It’s accompanied by not responding to the remote or even appearing in the APP, though the wifi indicator is showing a strong signal. Power cycling it, sometimes several times has so far restored normal service so I’m reluctant to sent it off just yet with the fault intermittent.
Any others had similar?
Next time It’s off I’ll try exercising the Burndy connections in case they just need a clean.
I should add there’s no sound when it does that, that’s the clincher.
I just checked and putting it into standby with the APP leaves the logo lit, I have my buttons dimmed but now it’s not responding to the remote and dimming them vas the last thing I used it for.
