Yes I run a Roon Nucleus (albeit not in a Naim system) with all my music on an internal 2Tb SSD. Not the cheapest way to implement a Roon core but as a virtually plug and play solution that you can fit and forget, it’s an excellent little box.
Roon will find a music store that is either directly attached to the hardware that runs it, or elsewhere on your network, just as a UPnP server can. So if you decide to try it, just remove the USB drive from the ND555 and plug it into another suitable device.
You could certainly plug the USB drive into the Nucleus.
I was offered a two week home demo of a Nucleus to try before I bought.
I found it sounded better than the high-spec fanless QNAP NAS I had at the time (greater detail and clarity, better timing and instrumental tones). This was using Asset as a server, which I preferred to both Twonky and Minim.
I also preferred the sound (for the same reasons) of the Nucleus with an internal high-quality SSD to an external drive. I had worried about this because some people have found disadvantages in SSD drives for SQ. I didn’t.
I compared this with a selection of files on a USB stick direct into the ND555 in server mode. I do not recollect the Nucleus seeing them as attached to the network and integrated in Roon. I’m not sure this is possible. I preferred the sound from the Nucleus to Server Mode. I think it’s more of a convenience function than anything else.
I’m very happy with my Nucleus+, which I use with a high-output Sean Jacobs linear power supply (another box!), which improves the SQ substantially in my system.
Thanks @Michaelb
That’s a ringing endorsement! More boxes yes, but a discreet one at least, and lots of functionality, especially if I fit an internal drive. A lot more than I was thinking of spending, but that seems to be a perennial hazard of hanging out around here!
