I’m sure that as always some will like and others won’t.
All good here, but no native support for Qobuz as far as I can tell…
Qobuz is not part of this firmware update.
Best
Thanks for confirming. For some reason, I thought it was!
Keep the faith! It will come one day…
Best
Bug fix for screen freeze?
That would be nice, not sure though…
Updated my ND555 yesterday without issue. Has anyone had a screen freeze post update yet?
My NDX2 screen is functioning as it should now after the update.
My NDX2 works fine after update, but I still have a problem that system automation doesn’t always switch my preamp from the turntable input to the NDX2 input when I play Roon. A restart of the NDX2 usually resolves that, until it stops working again.
I’ve just done the update on my ND555, and it went smoothly.
Thankfully, I can’t detect any effect on SQ, unlike the issues last time round on my NDS … and no more having to connect my laptop to the streamer, which, let’s face it, is so last century … so, that’s nice.
Good work Dave. My system is broken down at mo due to decorating etc. I’m looking forward to having all back up updated and running again.
Out of interest are the Muso range updated as well?
I can’t see any mention of the Muso in the software updates.
No the update isn’t for muso. They already have AirPlay 2, as do the new Unitis.
Best
I’m still waiting an update for the frozen screen in ND555
It’s in this update.
It was not mention…are you sure?
Where do I take the new update?
Through the app, a symbol should be showing top left of the screen, otherwise choose firmware update through the app menu, or screen menu.
