Hi, can anyone tell me how the ND555 integrates for volume control with the Naim App using NAC pre amps and also which pre amps support this. I believe its something to do with System Automation and maybe an interconnecting cable, but not sure.
Yes, you need a suitable cable with a 3.5mm jack for the 555 IR socket. Set up system automation in the Naim app settings menu.
This works with any current Classic or 500 series preamp.
