I’ve got the opportunity (should be with me tomorrow) for a home demo of the ND5XS2 (hope to hear the NDX2 at a later date) and as streaming is all new to me I am going through the Naim Support pages on how to set it up, use the Naim app etc.
I’ve came across a section headed “Set up system automation to Naim preamplifier” where it mentions that depending on your preamp model you may need to use a 3.5mm jack to RCA cable or a 3.5mm to 3.5mm jack cable to connect the two devices together. My Olive 82 doesn’t have a “Remote In” or "RC5 " input that you need to attach such a cable. As I can’t use “system automation” is that going to cause me a problems in getting the streamer or app to work? Does the absence of system automation only mean that I can’t control my 82 from the Naim app but that I will be able to control it just like I do now with the 82 remote i.e. will the volume control on my 82 adjust the volume of the music being streamed without system automation? (apologies in advance for such a basic question!)
You would need a 282 for system automation. If you’re happy with using the 82 remote, just carry on as you are now, using that for volume and input selection, and the Naim app to control the streamer.
@terry2020 It is possible to control your NAC 82 preamp through automation using the DAC remote control. You need to purchase an IR extender that has a 3.5mm jack on one end and a IR blinker on the other. My Naim dealer helped me purchase one. See picture below.
