ND5XS2 into Olive Nait3
Hello. I’m relatively new to the Naim world and loving my Olive Nait 3. I was thinking of adding a streamer like the ND5XS2 would that work and if so which input would I use? I already have a CD 5 and a rega planar 6 as other sources.
That would work - Just connect it to any spare input such as Aux or Tuner using the DIN5 interconnect that comes with the ND5XS2.
Thanks.
If you have both the CD5 and the ND5xs2 connected to the NAIT3 be sure to set the signal earth switch of the latter to floating.
FYI, this is a little switch at the back of the unit
