Hi, powered the system up this morning and the LED is flashing orange continuously. Power the ND5 down and back up, still doing it. Never had this before but is working fine, streaming radio as normal, so I am confused. The booklet says that orange flashing means that it is setting up the network. But the ND5XS2 is clearly connected to the router and the only other connection is the USB SSD. Any clues?
And now the radio has stopped, so I am worse off than ever.
Try factory reset. You need a pin to access small button via a hole on the rear, push and hold for 8-10 secs
Thanks. Fixed. An easy one!
