I guess Naim should be towing the line and not openly telling people to use a workaround to avoid energy saving measures imposed under the EU ‘Ecodesign’ directive.
Perhaps there are two factors to consider here:
In standby mode, enabling server mode will keep the streamer warmed up, potentially improving sound quality.
In use, enabling server mode might generate electrical noise, decreasing sound quality.
At risk of sounding completely obsessive, perhaps the optimum would be to turn on server mode when you’re not using the streamer, then turn it off when you play music
As a side note, I just, this very minute discovered that you can ‘share’ ones playlist in the app. However, when I press share nothing seems to happen.
Okay. Things got very Friday 13th. My nd5xs2 stopped making any sounds. I was listening to NTS radio and switched to some tidal and there was silence. And there’s no sound any more out of any inputs: radio, tidal, local.
I tried on/off, factory reset. Nuthin.
Bad luck.
