Am interested in the ND5XS2 to replace my existing 272 (with TXPS). Just wondering if existing owners of ND5XS2 are using with external DACs or not. If yes, which make?
Some advised that the SQ of the ND5XS2 is similar (or marginally better) to the 272. Obviously, the NDX2 will be better but I have a budget to adhere to (having recently bought the 252 + SCDR).
Would appreciate some insights so that I can make an informed decision.
Source first. Forget the ND5XS2. Why get a ācheapā source with an amp like yours? Doesnāt make any sense. Wait and get an NDX2, or get cheaper amps with an ND5XS2
@Simon-in-Suffolk runs an NDX2 and Hugo 1 into his 552. Somebody else wrote recently that his Hugo 1 was at least eye-level with his NDSā¦ So I donāt see why an ND5XS2 (as a transport) plus a top-notch DAC (a Hugo or something else) should be inappropriate for a 252. Obviously, one might not like the Chord sound ā but thatās a different issueā¦
If you like that combo, an ND5XS (with new streaming technology) and Qutest might become rather attractive; or something like SOTM 200, Project Stream Box Ultra or Allo DigiOne Signature instead of Naim as transportā¦ Any of those combinations is well below 5K; and you might like it more than an NDX2ā¦
I am actually feeding the Qutest by SoTM sms-200 Ultra Neo . The third source is Oppo UDP-205. I have 3 sources feeding the 252. Just wanted to streamline. Letting the 252/SCDR burn-in at the moment before deciding which to keep.
I prefer this over the 272. At the moment, the order of prefernce is the Oppo 205, Sotm/Qutest and then, 272. But I am sure things will be different once the 252/SCDR settles.
I am surprised that you like the Oppo the best ā Rob Watts and Naim will cryā¦ But, as you say, let the 252 settle in; and then explore your options carefully. There are so many different ways to skin a cat in the digital world, where one might not need to spend tons of money to get the sound rightā¦ Personally I am amazed by the sound my small Hugo 2 producesā¦
Do they have enough āoldā DAC chips for this? Of course, they might pursue entirely new avenues, but then the DAC in the new streamer would look old rather soon after their releaseā¦
