Ndac alternative
I would appreciate hearing about your experiences. My current setup uses an NDAC + 555 P.S+ ND5 XS2 as the digital source, within a system featuring a NAC 552 DR and NAP 500 DR.
I am considering replacing the DAC with a Chord Hugo TT2 + M Scaler combination, while keeping the existing streamer. Does anyone have any insights on this?
@ditton66 I am not a big fan of separate DACS, so take what I say with a pinch of salt. If it were me I would upgrade the streamer to one with a built in DAC The NDX2, 333 NC or the 555 are all options, depending on budget and end goal aspirations. .
There is no alternative to the Ndac :slightly_smiling_face:
@AndyKH Everything in audio has an alternative.
The replacement you are thinking about does not sound like your current system…….be careful, you have something special, once its gone?
Keep the ndac and buy a good quality modern streaming bridge.
The Nd5xs2 streaming board is pretty basic and 10 years old.
We’ve posted about this before.
Have auditioned a number of DACs for upgrade on nDAC, but the trouble is they all sound so different!
So it depends on what sound profile you like - nobody can make this decision for you.
Chord Dave, Weiss 502 sound cleaner/more analytical. But are they more “musical” in terms of enjoyment? Lot of cash to spend at risk.
I’ve no doubt TT/mScaler will sound fab, we quite loved the Dave. Chord has a distinct signature. DCS sound great, but not heard the Lina X.
Gustard cover both camps with the R30 (R2R) described as organic, whilst the X30 (ESS) is described as revealing. Have not investigated those yet, or the Holo Audio Spring 3 KTE, also R2R. At the price point these might be sideways moves, but all these DACs are very well reviewed.
Ultimately we have stalled. Speaker upgrade is probably first on list, but we’ve reached an impasse there :worried:
We have no intention of changing the NDX2 as transport, it stands up well. Plus we would lose system automation. Single remote is very handy.
My experience is quite different, Chord analytical, Weiss engaging.
DACs, like speakers, will generate all sorts of opinions. None wrong!
Much might depend on the system the DAC was auditioned in. Also, musical taste. The nDAC isn’t the last word in detail, but has other strengths.
We would definitely be wanting an extended home demo before any change….
It does detail with the right streaming bridge.
Recommendations?
We hadn’t really considered the NDX2 as holding our system back, but are open to options. Others use the NDX2 with DACs like the Dave.
Losing system automation would be a pain, but not insurmountable. After all, SWMBO eventually grew accustomed to the loss of digital volume control on the 272!
I’m using a Primare NP5/ifi power supply/VDH optical cable with an ndac, it’s detailed, but not in your face. More, detailed and delicate.
If you look at the NDS end of life thread, a couple of people have been using the NP5 with the NDS and been very happy. Although recently they’ve moved on to Lumin Mini and found that to be an improvement, although it is more expensive.
The primare is getting a bit long in the tooth, plus some people have found the app can be a bit buggy.
I won’t be swapping my NP5 for Lumin, but if I didn’t have the NP5, I’d probably go for the Lumin.
There are other makes as well.
Maybe try the new V3 firmware on the dCS bartok and rossini? Soon to be added to the rest off the range.
You then have 5 different sound profiles to choose from and more filters as well to fine tune the sound.
Had heard that, but when both DAC and streamer are different you don’t know what’s changed at each stage.
We had attributed “more detail” to the DAC, perhaps erroneously.
I thought exactly this!
Not sure where you deduce this from as to my ears it’s perfectly detailed and any more would be bordering on clinical.
The Chord and other non-Naim dacs I have tried wrecked the Naim sound for me, that includes Qutest and TT in my system.
The only way forward is ND555 :grin::musical_notes::musical_note::ok_hand:
But best til then to just chill and enjoy the excellent sound you have.
I now use a Naim CD player. Previously a Moon CD transport/Qutest DAC. Naim appeals to the heart, Chord to the head. Very, very different indeed.
Its all personal opinions, you already have a great source with the ND5XS2 / nDac, are you not happy?
Alternative dacs do NOT wreck the sound far from it.
I have owned a DAVE for about 5 years, simply the best source I’ve owned (my god its good) using a DR 552/500.
For me, using the ND5XS2 as a transport held back the potential of the DAVE, although very good.
The introduction of the Innuos Pulsar changed this.
Source wise - DAVE, Pulsar, MScaler job done in my books, music just flows, it is very hard to explain in words.
My door is always open to those who wish to call in for a listen.
I was using an NP5 with audirvana as it was the only one I found to be stable via UPnP (despite what audirvana say their UPnP implementation is absolutely rubbish)
Replaced it with a Holo Red and have been using that with Audirvana and Roon (couldn’t live with the sound quality of Roon until I got the Red)
I was originally using a Chord Qutest then switched to using the NDX as a DAC and thought it sounded much better than the Chord so then switched to nDAC with XPS2 and very happy now.
The Chord was great with the Quad 3 amp as it’s forward/detailed presentation worked with the softer pipe and slippers sound of the Quad but changing to Supernait 3 it was just too bright.
