Ndac optimisation
Using one of these with XPS2 non DR. Going into a 252 250 Stock cables on both. I will at some stage upgrade to a non DR 555.
I still have my Vertere Redline RCA to Din from my Chord Dac. Would the din din Version be better?. I have tried the lavender and this also works nicely.
Both my transports are RCA out. Using a Chord Prodac RCA RCA from a Meridian 200 and also nice results with a Rega Apollo.
My streamer is the Innuos Stream 3 - Using a Van Den Hul First Ultimate RCA RCA
Is there any benefit on going RCA to BNC and Using the BNC inputs on the Dac. Both sound great
That’s a brilliant set up. Congrats.
Innous Stream 3 is a great streamer - as transport - are you using with SPDIF digital out module ?
Maybe look out for a Naim DC1, ( directional as RCA Phono to BNC version) , which can be found pre-loved from time to time. New ones available form any Naim dealer. Others may suggest digital co-axial cable alternatives, which is fine, which very much depends on preferences. The DC1 works pretty well.
Good luck.
R
I also have nDAC with XPS2 non DR and the biggest improvement was using an audiophilleo on the Innuos Pulse to convert USB to Coax and then use a coax with BNC both ends (Belden 1694 with Canare crimp plugs) into the nDAC.
IMHO one of the most important things with the nDAC is feeding it a clean very stable SPDIF signal.
Hi re the Innuos. Yes I got the Spdif board. I do like playing CDS as well
A really lovely setup. Enjoy! I use a Superlumina DIN-DIN cable between the nDAC and the Nait50. It made a massive improvement compared to the Lavender cable. Others on the forum have confirmed this too. The Superlumina is expensive, but I bought it second-hand and, in my experience, it’s well worth the investment. With the nDAC, it’s also important to ensure the latest software (version 4.11.8) is installed (see Naim’s update page - Click here ) – a free upgrade.
My Olive XPS (connected to the nDAC) is also very sensitive to power cables. I’m currently using a Furutech DPS-4.1, which has brought a significant improvement over the standard Naim cable (if interested - click here). It’s worth experimenting here (perhaps also with a Naim Powerline).
Many people use a 555PS with the nDAC. There’s a broad consensus that this is a significant improvement. However, my nDAC is already 15 years old. That’s why I’ve always hesitated to invest 4.5k or more in a second-hand 555PS.
