Hello everybody.
can someone help me understand the procedure of updating the ndac chin?
I know there is also a procedure to see which firmware is installed.
thank you very much to everyone
Itās worth reading through this.
https://www.naimaudio.com/news/21751/dsd-playback-now-available-naim-audio-dacs
ok thanks Iāll try to readā¦
Thereās also a way to check the firmware version if you have an iPod/iPhone. Youāll have to scroll toward the bottom on the chain.
- Power up the nDac.
- Plug your iThing into the front panel āUSBā port - you have to make sure that the iThing is ādockedā (press the dock button if it isnāt)
- On the iThingy, go to Settings/General/About and scroll down a bit until you see Naim Dac. click on that and youāll see the firmware revision - latest is 4.11.8.
Hi,
it is important to disconnect the power cable from the dac and the power supply for a few minutes, the time to empty the dac buffer. Before proceeding with the update.
ok thanks a lot Iāll try to do it
Let us know how you get on @tarantina5555. Iāve owned one from new so Itās about time I did the update too
Hello @tarantina5555. I did the upgrade last night. Very easy and the process was straightforward. Have you had the chance to do the firmware upgrade yet? need a hand?
