A further project with my NDS giving it another further boost
1. New version of SonoreUPnP Bridge on SonicoribiterOS v3
The SonoreUPnP Bridge has been completely, from the ground up, rebuilt on a new SonicOrbiterOS in v3 form. The new OS provides a platform for new and further services relevant to NAA based usersm, but here the new version of this Bridge enabling Roon direct integration with an NDS through the Ethernet input is just sounding wonderful.
Not sure what has changed in the underlying OS and Linux kernel to allow this and why it is having an effect, but it is.
Taken some time to knock the bugs out, including a nasty end-of-track stream termination issue that was making the NDS hang, but all resolved now through support from Sonore principle.
2. A new protocol connection in the playback stream
I have been following Diretta, an optmized protocol stack for audio, that removes much of the ‘stack handling’ within Ethernet packets with a view to support a direct flow of data from the server (Roon) to the DAC. There are a number on the Roon who are building 3-Tier architectures with RPi5 units with a direct point-to-point Diretta based communication before a USB based DAC connection. They have been getting excellent results from this.
Sonore has recently introduced something similar - ‘Sonore Link’ which sets up a L2-RAW connection between two Sonore Rendu units. They have to be running the latest Sonicorbiter OS v3 (which was a free upgrade). One unit is configured as a ‘Sender/Bridge’ and the other ‘Receiver’, which is very similar to the Diretta ‘Host’ and ‘Target’ architecture.
The L2-RAW connection is just Layer 2 Ethernet frames between two endpoints identified by their MAC addressees. There is no UDP, IP addresses. The frames are relatively small, so there is a constant stream of frames between sender and receiver removing any network based ‘burstiness’, particularly present with RAAT and UPnP. The intention is to remove as much of the processing overhead, the network noise etc.
For my NDS, I take the USB output, which in ‘Tuned mode’ moves interrupts off the core feeding the DAC, pins the receiver beside the USB controller, stops services the receiver unit does not need to play, and turns any LEDs off and pass it into a Sonore UltraDigital DDC to get a S/PDIF signal out for the NDS digital input.
I am also using an OpticalRendu as the Sender/Bridge with an opt-isolating fibre connection from the STP port on the A side of the EtherREGEN. The B port of the EtherREGEN goes to the UltraRendu configured to as the Receiver. The UltraDigital is powered off the USB VBus, so further separate power supply, so is using the same power input as the UltraRendu, a Uptone UltraCap LPS 1.
I am using this with Roon, which manages my local library and any internet-based streaming services whether Tidal, Qobuz or Internet Radio, so these don’t connect direct to the NDS through the internet, which isolates it from any internet-based noise, inter-packet latency etc. that is present with these services.
I need to spend some further time evalulating this new L2-RAW protocol based playback path, but it is certainly sounding better than a direct S/PDIF feed coming from Roon through the UltraRendu. And although the new SonoreUPnP is sounding better than the past versions on SonicOrbiter 2.9, 2.8, 2.7 etc. this L2-RAW based connection is already sounding cleaner, with blacker background, better definition to the leading edges - all signs that noise has been further removed.
