Hi, I remember there being a thread about this on the old forum. I want to update to 4.4 (or whatever the latest version is) but can’t remember how to do it.
The latest version is 4.6 but you need to update to 4.4 first if you are presently at 4.3 or below.
You can find both updates with instructions on Naim’s website. I’m not looking at it now but it’s in the customer support area.
Best
The update instructions are included in the firmware zip file as well.
Yes, just download the update, and you’ll see the instructions included with the actual firmware.
You can try 4.4 and then 4.6, and you can go back to 4.4 if you prefer it, which I did.
You will need this page
Instructions are in the zip file.
Thanks!
+1
