Hello everyone.
That’s my problem. I have been experimenting with dematerialization for 3 years and I am very satisfied. I started small and very simple to “tame” the thing being a non-geek and not wanting “headaches” during use and installation.
I currently have a BS Vault 2 with NDac/XPS. I am very satisfied with it. I optimized the network with an Uptone Etheregen + Paul Hynes psu + external clock, but also good quality RJ45s.
But, I want to evolve and I think it is possible to go further in the SQ…
I was recently able to test a Qute at home, then an NDX as a streamer on my NDac/XPS, no photo, it goes further in all areas. But for its price the BS is an excellent streamer coupled with the dac. I could have gone on like this for a long time…
After this experience, I want to change streamer. So I hesitate between an NDS, and used NDX2. The NDS is certainly exceptional but the fact of not being able to exploit it to the max with a 555 PS, that Qobuz is not native on the app puts me off.
While the NDX2 is certainly different, a notch below, but where everything is integrated. I was thinking of coupling it to the NDac.
I really like the Naim Dac for its PRaT, and its very analog character. The NDX2 /NDac/XPS should be very similar to the NDS due to the use of the same D/A chips for the digital conversion circuits. What do you think ?
Otherwise do you think that an ND5 XS (1 or 2) as a streamer can reach the same level of quality since I will only use the streaming part? Or is there a gap at the SQ level compared to a bare ndx2?
Complicated huh?
If you could help me in my thinking.
Thank you in advance for your feedback.
