I cant get the artwork/covers to display on the front panel USB input. The same FLAC files work OK with embedded covers in the downloads folder. Is there a different folder tree required for the USB ?
I don’t believe you’ll ever get the art if you use the USB. It’s just the music. There is no upnp server in play to send the art, and the player is simply dragging the files from the USB.
