Hi friends,
What brands of USB sticks best suited to the NDS and what is the maximum capacity you have tried and worked without issues ? What format should they be initialized for smooth operation?
Thx.
Hi friends,
Thx.
The older generation Naim streamers have a very basic folder view which means that they are not ideal for large music libraries. Other than that I find that any USB stick will work fine, so I wouldn’t bother with anything expensive.
I never bothered to format any USB stick, for me they always worked straight out of the box, but the official advice is to use FAT32.
I used before Sandisk usb sticks, up to 500 GO. The sound is really good and you can use the remote. But you need good eyes to see the screen.
