Hi all I hope you can help!
I’ve just upgraded from Nd5xs2 to the fantastic NDX2 and I’m loving it so far.
I have one small issue, so to all you knowledgeable people.
Should the main screen on the NDX2 show the server, tidal and Qobuz inputs?
The above 3 inputs work fine from the app but I can’t select them from the remote or device.
Your help would be much appreciated.
Hi, these inputs can only be controlled from the app. It seems odd to me that Naim moved to a fancy new Zigbee remote control and colour screen, but removed the ability to control these inputs which was there in the old models.
Thanks Chris for the clarification.
Yes seems strange on Naims website it states you can select the server input from device buttons, remote and app.
Mine is only showing these inputs on the app.
As a soon to be new ndx2 user can anyone explain the various volume control methods via automation and what will be seen on the app/ndx2 screen. My understanding is that fixed volume is preferred for sq reasons but no numbers appear on the screen.
@Turbo this might be a dumb suggestion but have you checked in the App (Settings/Input Settings) to make sure that the Music Server / Tidal / Qobuz Inputs are enabled ?
*edit, should have ready your first initial post, sorry!
