NDX-2 with XPSDR
There have been some responses over time that mention that they have a 555-DR with the NDX 2. A couple of people have mentioned that they have had a demo of both the 555-DR and XPS-DR and chose the XPS-DR. Main reason was cost (USA Pricing) with the XPS-DR at $6599.00 vs the 12,999 for the 555.
I chose the XPS-DR after a long home demonstration with my NDX 2. I did not demo the 555, I’m positive it would have been an improvement over the XPS-DR but could not (would not) spend that much for a Power Supply for the NDX 2.
I can only relate my experience with the CDX2. The 555PS was a much bigger improvement over the XPS than the XPS was over the bare CXS2.
I use my NDX2 with 555PSDR. I bought mine pre loved to power my (then) nDAC. It’s now taking over PSU duties with NDX2. It’s sounds awesome and definitely staying in my system
I have mentioned this before but it’s an option for those with a 282/HiCap.
Rather than spend the money on an 555PS for my NDX2, I bought a XPSDR and also upgraded my 282/HCDR to a SuperCap DR. Each of them contributed improvements, but the added advantage of the SCDR was that it also gave my analog source a lift.
Disregarding other sources, I wonder how the two might compare. Adding a 55PS to a NDX2/282/HC system (leaving the HCDR alone) or adding a XPSDR and upgrading the HCDR to a SCDR, as I did?
I have used an NDX-2 for quite a while. Adding the XPSDr made a big difference: more detail, better soundstage and better imaging. All without loosing any of the boogie-factor or timing. I’d recommend anyone using an NDX/NDX-2 to add a PSU.
Today I replaced the XPSDr with a 555Dr. Been searching for one on the second hand market for quite a while; they are not offered very often. Even the system played only for a few hours now, the changes are remarkable: a lot more « authority », more detail and especially individual instruments that are better separated. One can hear it immediately. I read a lot on the 555dr but never expected the change this impressive.
Iver
When considering a 555dr, I’ve seen a few that are labelled CD555DR second hand for sale. I assume these are just the same?
Yep, if you look at the Naim product page for the 555PSDR it still shows the CD555PS label on the rear picture…
Have the 555Dr now for a few days feeding the NDX-2 replacing an XPSDr. Observations confirm what I already and shared earlier: more authorithy, better separation of instruments and better imaging. An additional thing I noticed that the bass control bettered: I had the rear bass-port of my Kanta-2’s closed using some foam. Reason was a slight booming with some records. With the 555Dr it is better to have the bass-ports just open en breathing. It gives more bass and doesn’t loose control. Very happy with that
Iver
