Mate run a cat 6…
I’m no spark but did mine and all went ok… Buy the unconnected cable and terminate it at the router/ndx… (smaller holes to drill) and the plugs are easy to terminate…
Well worth it mate
Mate run a cat 6…
Well worth it mate
Unfortunately that’s not really an option due to layout
If you use multi room you can effectively listen with Qobuz on your NDX2 multi room linked to your MusoQb.
Yes. Have just been doing that with NDX2 and first gen Qb, albeit with Tidal, but I’m sure Qobuzz would also work.
Paul
