Hi.
Sorry posted in hifi corner didn’t realise there was a separate streaming forum….
I have an original 24/96 ndx from 2011. On the latest firmware 4.8?
But don’t have a tidal input on the app (latest version of the app) it should work on this right? It’s on the network as I can use it to stream locally.
Can turn other inputs on and off. Oh and of course the screen has gone, but don’t normally need it. Being so old I’ve been told we can’t get a new screen from naim, so can anyone confirm if tidal should work.
If it should work anyone got the menu path if I need to turn something on, even if it’s by touch.
Cheers.
Also out unitiqute mk 1 logs in fine to tidal, and both are dhcp on the same network, so unlikely it’s a local network issue. Same network connection works on the qute just as an example.
My router firewall is disabled so don’t think the internal network is the issue
