Ndx digital input settings
Hy all, I have a question. So I buy a silent angel transport munich m1t and Connect my ndx with coax. Which digital input settings is better for me, unstable yes or no? And my tv is unstable yes or no
Thank’s for help
My NDX has TV (sound) connected over Toslink (optical) and Unstable Source set to NO.
Thank’s,
No is the default setting and tou should normally use it for all devices. Only set it to yes if connection is unreliable when playing music.
Thank’s
Sorry my stupid question but what is “unreiable connection”?
Good question, I guess if it doesn’t sound OK, like jumping/stop/start stuff its unstable.
A the time (2016) I thought the way the instruction is worded to be a bit ambiguous. (unclear/double negative)
