I purchased a used NDX. I mess with it several months ago trying to get it set-up to stream.
Even with factory reps via the phone.
Here’s the" Iron door" I’ve entered the router PW . The press OK on the hand set.
The NDX displays PLEASE WAIT trying to make connection. Then DISPLAYS connection failed ‘TRY AGAIN.’
I did! over& over SameO. Rebooted everything 3 Times. Yes! SameO
HELP
Tunes2
Have got an NDX manual & are you following the setup instructions.
I suspect the previous owners IP Address settings are blocking you. best to reset it to factory defaults and then restart the NDX. This will reset the NDX to have the IP address set over DHCP, & that’s what is defaulted in factory default, and it’s best not to change that.
Sonwleo
I did all of that several times. But! it will connect to Tidal or Spotify
via Ethernet cable direct from my TPLink router.
I don’t know if it’s internet card serves both?
Tunes2
