As per the title really.
After a while, if I line up an album for the NDX to play, it will play the first track then stop.
If I reboot the NDX and line the album up again, it plays to completion.
I’m on version 4.6
Any ideas?
KR
Simon.
I suspect this might be a function of your media server. What is it ??
How is it connected? Ethernet or Wifi?
Not sure this will solve your problem, but the latest firmware is 4.7, so I would recommend that you update it anyway.
I have the same trouble with my 272 with playlists. If I play a playlist from Tidal it works just fine but if I play a playlist or an album from my Unitiserve I often get only the 1st track. Sounds like it is a US issue but I’m using 1.7c so I don’t need an update.
It’s really annoying having to reboot everything early regularly. Any ideas what the problem is and how to cure it?
It is Ethernet connected, using Twonky.
The release notes of 4.7 make no reference to this fix.
I have been through a number of beta versions of 4.6 & then the final version of 4.7 & they all worked perfectly OK with no hint of this problem, so I don’t believe 4.7 is the answer, but why not do it anyway.
I don’t know Twonky other than helping a mate with it, & I was not impressed to say the least.
It it was a problem on my Synology with Asset, I would clear all the cache’s & either restart or delete & then reinstall the latest version of Asset.
