I have an original 24/96 ndx from 2011. On the latest firmware 4.8?
But don’t have a tidal input it should work on this right? It’s on the network as I can use it to stream locally.
Can turn other inputs on and off. Oh and of course the screen has gone, but don’t normally need it. Being so old I’ve been told we can’t get a new screen from naim, so can anyone confirm if tidal should work.
If it should work anyone got the menu path if I need to turn something on, even if it’s by touch.
Cheers.
Also out unitiqute mk 1 logs in fine to tidal, and both are dhcp on the same network, so unlikely it’s a local network issue.
Cannot help re: your tidal question but on the screen front I’ve recently had the screen on my NDS replaced by Naim. I’d be surprised if the NDX screen differed (I have a NDX too). Cost in the uk was £159 plus £20 one way shipped on a ‘screen only repair’ basis which in this crazy price world didn’t seem too bad to me. For me on an nds it was a worthwhile expenditure but obviously proportionate to s/h value a bigger decision on an NDX.
I asked cymbiosis and they said no. I think because it’s 24/96 the newer ones are fine. Mid/late 2014 isn’t it? Are ok. But my 2011 isn’t. The French guy does ones but need to do some soldering at very small levels to get it working
You need the 24/192 board to be able to log into Tidal via the Naim app and also you need the 24/192 board to be able to get the screen replaced as the currently available screens needs software module that won’t run without the 24/192 board.
Unfortunately the 24/292 board is no longer available from Naim as the key semiconductors (eg the processor chip) are no longer made.
Yep lots of ways of doing it. I only needed to know if it would work natively I know how to get it working none natively I just asked if I can do it natively, the answer is no
If I can find a way to close the thread it’s been sued and answered, thanks for all the replies.
