Hi NDX Owner,
Are your unit’s front panel exit light always ON ?
marcobb0312
No, its always off.
My one is always ON
OK, I understood that by your 1st post.
Yours has a defect.
Have you tried a power cycle ??
I just get back my unit from dealer and found this issue.
I don’t remember it has as before or not.
Take it back to the dealer.
No lights should be always on
Just take it back and return on position,
I can confirm that as Mike says, mine also remains off. I think you need to ask your dealer to sort it out. If a restart doesn’t fix it, you could try a factory reset.
