Is it possible to run the streaming section of an ndx to an external dac? I have a decent dac I would like to compare to the internal dac on the ndx. Looking at the functions on the naim app I don’t see any way. Any help would be greatly appreciated! Mike
Yes - just connect the Digital Output via a coaxial cable to your DAC. Remember to enable the digital output in the setup menu (from the front panel controls).
Thanks James! I got it second hand without a manual.
Ah ok. Manual link here if you need it
