I have tried multiple times to upgrade my NDX2 from 3.7.0 to 3.7.1 and it has failed each time. My app is up to date. I have tried from the app and the on screen menu.
It downloads and looks like it is going to work then just sits back and the firmware downloading screen and does not update.
At this point I can access the NDX2 from the app and play music. However I cannot power it off using the app or the top right power button on the NDX2.
I have to power down my 555DR PS to get the NDX2 to reset. It then works fine but with 3.7.0 firmware.
Thanks for the feedback everyone.
I have now upgraded. Not sure what the root cause was.
However factory reset and power down of NDX2 and router has worked.
