Thanks Simon.
Several very informative and helpful posts there.
I am trying to achieve better SQ.
My ideal is that Naim will launch a 472 - with the new streaming platform; with no internal psu; with twin Burndy inputs for digital and analog circuits; with an optional headphone amp; with no phono stage, screen or volume knob; with the same excellent volume control as the 272.
That would make a serious dent in the market, and consolidate Naim’s long-standing reputation for innovation - and play to the demand for getting more from fewer boxes based on reducing electricity consumption and materials usage, as well as space constraints in modern homes.
Anyway, I’m looking forward to the revised 272 - if that does emerge, although it may not fit my exact brief.
But at some point - say in June - if it doesn’t emerge I may just go down another route.
One other way forward is to max out my 272/555DR even further.
One way to do that is to get a upnp stream to the 272, which I’ve been often told gives a better SQ because it takes processing work away from the 272 streamer (inc. transcoding to WAV?).
So I guess I could achieve that and also get optical isolation by buying a Sonore opticalRendu?
Another way to get that and extra other benefits would be to get an Innuous Zen or Zenith server and stream Qobuz/Tidal from it?
Qobuz should also add SQ over Tidal, which is what I currently use.
One other option would be to get an EtherRegen switch?
So I’m trying to find out which of these routes might be best to go down, or whether I’m missing some other way forward.
I don’t really want the complexity and expense of Roon unless it’s clear that I can get a SQ boost with Roon that cannot be obtained in any other way.
