Hi all.
Again in problems, this time with the NDX2…
Until last night, no problem with the NDX2. This morning, already 2 hours trying to make it sound and…, nothing, it doesn’t work…
What’s going on?
No idea: it turns on well, connects well to the network, the network works well and recognizes it instantly, but… I try to connect with the Internet radio stations and the logos have disappeared, does not load any stations, initially the message “stopped” appears, the screen goes black and…, from there it does not come out except turning it off and turning it back on. I try to connect the UPnP NAS input, or Tidal’s, and the same thing…
The router works perfectly, the network works well on all other devices, Tidal also…, there is no IP conflict…, but the only entries that the streamer allows are the local ones (USB, TV-Toslink, CD-Digital SPDIF); with Internet Radio (VTuner), UPnP (Synology NAS) and Tidal inputs, nothing, the APP works perfectly, discovers the device, charges Radio stations, NAS and/or Tidal and seems to play normally, but the NDX2 tries to load, black screen, and from there it does not come out…
What have I tried…?
Reboot router and NAS, restart NDX2 to factory reset, UPnP and Tidal operation on all other devices which are all OK, check IP conflicts that there are no…
I have tried to contact Naim technical and support service, but it seems that everyone is on vacation until January 02…
Has anyone had something similar happened…? Does anyone have a remote idea what might be causing it…?
I’m beginning to think that the problem is in the NDX2, and, after all the expense on the new components, including the NDX2, and the work and effort in the installation, I’m climbing the walls…
Mysterious, because in the month and a half of common life with the NDX2, it has not given the slightest problem, but from yesterday to today, without change any in the configuration, nor the installation, nor anything, this…, as I point out, is incredible but real…
Ufffff…
Thanks in advance.
