NDX2 & Vtuner Issue
I’ve just set up my new NDX2 but having problems with internet radio, the factory preset stations work ok but can be a bit lazy switching between them however it won’t load any vtuner options to change stations etc. Tidal works perfectly as does my local server. I’m using wired Ethernet and have rebooted router, switch and also reset NDX2 to no avail, I’ve also tried Wifi and no different. When using tidal it can be lazy switching back to radio and takes a minute to switch. I’ve used the same setup with a Muso, Atom and Nova with no issues, any thoughts?
I’ve been listening to Tidal and Internet radio today on my NDX2 without any issues. I’ve set up a few radio stations as favourites (just tap star on the station playing) so I see them under the Radio tab on the main screen in the app. Saves jumping into Internet Radio and searching for fave stations.
