How can be explained “ through the hole” ? In other words
It applies to components that are fitted to the PCB but threading their legs through holes in the PCB and then soldering
Thanks. I thought there was only 2 possibilities, as mounted by hands ( all connectings done by hands ) or something made in chain by a machine and put in the box.
Apparently you are referring to something else.
Traditional
Very clear ! Thanks
Surely some difference in the larger PCB will be inclusion of the Burndy power input?
Simon S gave the response above.
