Having powered up after a thunder storm my XPS is dead - I suspect it is a blown fuse. I have replaced the fuse in the plug but it seems the fuse in XPS itself has gone and there is no spare - grrrrr!! To compound matters having disconnected the burndy and connected the NDX2 to the mains directly the on/off button is flashing in a sequence 0 -3-0. Ideas anyone? I’ve had a look at the manual but nothing obvious there. Thanks chaps!
Forgot all about that link plug as its always been powered by the XPS! Found the plug in the box and powered up successfully. Now to get a fuse for the XPS! I assume it is a fuse problem as the fuse in the plug also blew.
Be absolutely sure to replace with exactly the correct value of fuse(s).
The one inside the XPS2, as specified by Naim is: 20mm 2.5A 250V Slow Blow / Antisurge fuses – Naim use fuses made by “Littlefuse” from their 213 series.
Available from your Naim dealer or from RS Components.
An XPS may differ from the XPS2 so I suggest calling your dealer to confirm.
I discovered that when I plugged the XPS back in it wasnt plugged in properly which I think was the root of the problem. I have never previously had any fuses blow on my system. Will soon know when I replace the XPS internal fuse!
Plenty of future stock here - I dread the thought of no XPS DR. OTT? Maybe, but the way things are going with global supply chains, I’m not taking any chances
Definitely no spare and the fuse has also definitely gone to the electrical spares shop in the sky. Fortunately the glass is only cracked rather than completely blown. Gives me some measure of comfort that it is almost certainly just a fuse problem - phew!
My XPS is as dead as a dodo after replacing the fuse - back to Naim I’m afraid. My NDX2 is still very good without the XPS - but not quite as good. Difficult to identify what it is, just something missing somehow.
I’m making an assumption here (I live in North America), but is this fuse thing only on 230V units? I’ve looked everywhere and I don’t see anything where a fuse could easily be replaced.
Yes we do, back to salisbury it goes. I tried 3 or 4 times taking the new fuse out and putting it back in - no effect. It needs some time on the operating table. It will basically be serviced which although its only 6 years old is not necessarily a bad thing.
