Hi all,
I wanted to share a bit of my experience and open a discussion, as I suspect I’m not the only one in this situation.
My current system is a Naim 282 / HiCap DR / 250 DR into Sonus faber Sonetto V.
For the source, I use an ND5 XS2 as a transport into a Chord Qutest DAC powered by an Sbooster. I should add that I’ve experienced very similar behaviour when using a Naim nDAC as well, so this doesn’t seem specific to the Chord DAC.
The room is a living space of about 35 m² (377 square feet) not a dedicated listening room. The speakers are spaced about 2.3 m apart and placed roughly 1 m from the rear wall.
What surprised me over the last few weeks is that, after a lot of experimentation, I consistently get more depth, immersion and emotional engagement when I radically reduce my listening distance. I now tend to listen at around 1.1–1.3 m from the speakers (almost noe toe-in), which is clearly closer than the “classic” equilateral triangle usually recommended for floorstanders.
At this distance, the presentation becomes more immersive, more precise and nuanced, rhythmically stronger, with a much clearer sense of front-to-back depth. It sounds coherent and emotionally engaging. When I move back to a more “normal” listening position (equilateral triangle or close to it), the soundstage feels flatter and I lose that sense of being inside the music. I doesn’t always sound « right ».
This raised a few questions, and I’d be very interested to hear other members’ experiences:
Have some of you noticed a major improvement by significantly reducing listening distance, even with floorstanders?
Were you eventually able to recover a more conventional listening position (equilateral triangle), for example through room treatment or setup changes?
Or did you conclude that nearfield listening, and possibly headphones, was simply the best overall solution in your case?
One additional element that may be relevant: I’ve listened to music mostly using headphones since childhood, so my perception of immersion, depth and intimacy may be naturally biased toward a high ratio of direct sound versus room sound.
I’m not looking to criticise room acoustics or chase upgrades blindly, just trying to understand whether this is mainly down to listening history, room interaction, or something others here have also discovered over time.
Looking forward to your thoughts and experiences.
