My new Guru Q10 speakers appear to be stuck somewhere between Estonia, Sweden and Austria. Tired of waiting (I have waited for four weeks now) I pulled the trigger on a pair of display model Neat Iota Xplorer to give my SuperUniti something to play with. Two days later they were on my doorstep in Vienna, after a short trip from the Czech Republic, hurray!
According to Neat they need up to 200 hours to sound their best, but boy, did they sound nice right out of the box. Now they have maybe 25 hours on them and I can’t say that I have noticed much change. Hard to believe they could sound any better.
I loved what IsoAcoustics Gaia isolator feet did for my old Tannoy Cheviots (box upgrade level transformation), so I ordered the matching Gaia III for the Xplorers.
It will take a couple days for them to arrive, so in the meantime I wanted to check if anyone here would know (or wanted to venture a guess), if changing the distance between the (floor-firing) woofer and the floor will influence/change the performance of the woofer? I did a mock up yesterday with some wooden blocks and it did not seem to make a lot of difference, if any.
I will also inquire with Neat Acoustics on Monday.
The proof will be in the eating of the pudding once the Gaias arrive chez moi, and I shall dutifully report.
Cheers!
