How are you using a high pass filter for the SX2s? A normal speaker/subwoofer setup in most cases sends the full range signal to both main speakers and sub, with the sub using its built in low pass filter.
The quoted frequency range of the SX2 goes down to 35Hz, and the usual starting point for subwoofer integration is a little higher so that you have a little overlap. So I would start at around 40 to 45Hz, but just use this as a starting point and adjust up or down from there by ear.
