Hi… I literally just joined the forum so forgive me if this inquiry might be in the wrong place.
New Classic 200 series owner (Trio stack) I have been enjoying the system for a week and last nighj I played a little longer and louder than the usual.
As I was choosing track in between i heard a click or some tick sound from the NAP 250.
The amp was a little warm to touch on the left side, the sound seems to be ok but just got this annoying click every like few minutes.
Was it through the speakers or physically coming from the amp?
If the latter and if you say it’s warm to the touch then I wonder whether it’s perhaps a relay - perhaps turning on the fan cooling? Perhaps something that can be clarified by your dealer.
It’s hard for me to judge as I don’t really know what it is, and I’ve not spent much time with the new 250. You might be best advised to email Naim support and get their opinion here.
Sounds like the fan kicking in. Below link may help.
Question is, if it is the fan, why is the amp working so hard? What speakers does it drive? Size of room? What speaker cable & length? What kind of SPL is ‘normal’ for you?
It’s 39° in Abu Dhabi today, is the room the amp located in air conditioned? Even if so it could be the fan kicking in due to a combination of higher load due to louder&longer music session and highish room temperature?
Hi man… I literally have to put on a jacket as I keep the room at 23 degrees:grin: with my electric bill spiraling to 700 Dollars but now i resetted everything and disconnected all components… setting up and will keep you guys posted.
