After trading in my 272 on a 252/SC DR I’m now having to add a headphone amp. I don’t use the headphones much but would like to have to option if I need to. My dealer suggested a Headline 2 which apart from not having a remote suits my needs. Question is should I also purchase a separate PS like a NAPSC or run it off my 252. Just about every thread praises the addition of a PS to any of Naims black boxes so it seems obvious but some think it’s ok to use the pre amp.
Question is after an expensive upgrade that I’m very happy with and don’t want risk will I hear a difference either way.
Pete, I just added a Headline 2 when I purchased the 282. I was fortunate to purchase a used one from my dealer which have with a NAPSC and for me with my Grado GS1000e headphones they sound mighty sweet. I use the headphones the majority of time in the late evening when my wife has gone off to bed and having to set/adjust the volume manually has not been an issue.
I can not speak to running off the 252 but with the relationship you have with your dealer he should be able to loan you a NAPSC to demo to use for a week or more so you can make a decision.
My advice would be, if you can find a nice cheap one for sale secondhand then get one, but if paying new price then other options are much better value and can sound better as well
Pete, if you don’t headphones generally, why do you want absolutely to buy one?
Can’t you first borrow an headphone from a dealer, just to see if you will like enough the experience to use it regularly ?
If you have your pocket burning, I can send you my bank numbers account.
I’m lucky Mrs Pete would sleep through world war 3 and my studio is 3 floors below the main bedroom (and offset), so I don’t use them that often. We do have a lot visitors and it would be nice to have the option of using the headphones when needed. My dealer allows me to take anything home to audition.
