Need help connecting NAC282 to SN2
Sound is completely garbled… not sure if one or more cables from the hicap dr are the issue but thought I would see if anyone here has connected the SN2 to a NAC282
It’s very easy. Power the 282 from Hicap socket 4. Take a Snaic 4 from Hicap socket 3 to the SN. Make sure the SN is in power amp mode - see below.
Thanks hungry! Had everything connected properly… but didn’t realize the mute button needed to be held down!to put it into power amp mode. Cheers!
Excellent. It usually pays to read the manual as these things don’t always work as perhaps you may expect.
