For a few days now i need to double the volume setting of my Atom. In the past i listened at lets say 10 on the scale, now at 20 to get the same result. Nothing has changed to my set-up. I mainly listen to internet radio and listen to the same stations like in the past.
Anyone else?
Did the max volume setting change inadvertently?
It not, try shutting it down, unplugging it, and waiting 15 minutes before you turn it back on
That’s exactly the effect I would expect if the max volume was halved. Hope that’s the problem.
The behaviour of my Atom has not changed recently.
Roger
