My assessment of the bearing may be incorrect, for some reason I had assumed a convex sapphire on top of the ‘stainless steel finger’ and concave surface in the brass stem of the platter - quite possible I’m completely mistaken and the bearing is ok
Maybe just a bit of a clean and some fresh oil is needed.
I’ve just realised the PSU is not in the house. Probably in a storage unit in a box, but fixing PSU would be a good start, I assume caps may have gone bad.
Also, interestingly regarding Funk Firm, I spoke to Arthur about the bearing a couple of years ago and he was confident he could repair, though I wasn’t sure if this was going to entail some custom updates to the bearing or PSU using newer Funk designs, possibly resulting in a hybrid upgraded Anniversary.
Well, I have an olive NAXO and an olive SNAXO. I ran the NAXO from an olive Hicap, and simply replaced it with the SNAXO - may have been an uplift in SQ,… or maybe not.
But then I replaced the Hicap with an olive Supercap and its Burndy.
That was well worth while
