What headphones would you recommend (new, sub £200)?
Is the Cambridge MXN10 a suitable/ good streamer (new)?
I’m retiring soon and have rediscovered “noisy little boxes”. While I do have funds, I’ve taken the second hand route. My ears are not to the same standard as some, unlikely to upgrade these. You’ll get an idea of my budget from what I have or what I’m looking at. I’m aiming for good at a price, not amazing for a fortune.
I’ve already bought:
Nait 5si - love it
CD 5i mk2 - might be an upgrade later, but seems to match well with the amp, for now. Din5 connector.
Tannoy XT 6F - I know they are not everyone’s choice, but they work for me.
I would put the Mezze Classic 99 headphones on your shortlist - I have a pair and they are excellent. They cost £299 but Richer Sounds are selling them for £249.
The MXN10 is an excellent streamer for the money - I’ve heard it and was impressed
What @crispyduck said…
With streaming the App is also critical as well as WiFi or Ethernet connection and stability.
WiiM Ultra also a fantastic budget option with arguably better software and a more advanced DAC
You could audition Hifiman Sundara headphones. Bluesound could be a candidate for a reasonably priced streamer.
I use to have Tannoy XT 8F’s on a Nait 5si. Good choice.
P.S. When buying lower priced headphones don’t forget to look at the cable that is included. Lower priced headphones are often intended for mobile use with a short (1.2m or 1.5m) cable. Either make sure a long cable is included or look for a long replacement cable.
