I can easily imagine using the sound effect precisely to highlight the very artificiality of it, that would be a perfectly fine use. There are few things that are always wrong in art
No noticeable noise whatsoever in that case. As soon as I pause a recording, all noise is gone.
If you hear the same as I do with your system then case closed!
I’ll assume that not all recordings are noise free, a fact that was difficult to wrap my head around specially in recent recordings.
Thanks all for your help and taking the time to answer.
I’m a happier person now! Buyer’s remorse is over. Just will need to learn to ignore the noise when I hear it.
Thanks!
I think you have your answer…
An answer in 24 posts, take that, ethernet cable thread
Yeah so I was thinking about upgrading mains cables, what’s the community take on that?
Just joking.
