New firmware 13.10.1
Dears
Just installed new firmware on my Atom.
Do not find anymore Tidal in entry configuration !
See :
Normal?
Phil
It’s under ‘services and accounts’ rather than ‘system settings’.
You’re right. Thanks!
I actually had a brief issue with the update. (Uniti Atom). Once the update was complete - It froze the unit - remote control didn’t work and I couldn’t connect via the App. Panicked briefly - assumed I’d need to do a factory reset - started looking up how to do that - but someone on this forum suggested trying unplugging the power lead from the unit - leave 15mins and take it from there. Happily that did the job. All working perfectly now. Just thought I’d mention it in case anyone else had the same issue.
Just installed the firmware update on my ND5 XS2, quite quick. One problem, could only play Qobuz streams via the Naim app, local music via Asset uPnP wouldn’t play. Restarted Asset on my Mac and all back to normal now. Sounds good, as it was before the update.
