Hello,
I bought a new IPad gen11 downloaded the naim app and it doesn’t connect with my NSC222
Is your iPad on the same WiFi network as your NSC222. Or alternatively is your NSC 222 connected to your network by Ethernet?
Hello David,
yes and yes.My old IPad and IPhone still work with the Naim app.
It could be down to permissions, go to the Settings app, scroll down on the left to find the Naim app. Tap on it and make sure Local Network is enabled.
Yes indeed. And also it’s necessary to allow the Naim app to have access to location info as local WiFi is so categorised by Apple.
Strange … did you try restarting the Naim app, so closing it by swiping it upwards?
Yes I did.Still the same!
I’m not as knowledgeable as others here, but re-starting your router, switches and NSC222?
Yes I did😩
Restart your ipad
Hi Stocko,
I just did,and now the app connects to NSC 222.
Problem solved.
Everyone,have a nice weekend.
Good to hear that, enjoy!
